Britcheflee
Cannot get my 53 mercury to start - fires fine with starter fluid - I Think the mechanical fuel pump has stopped working - I attached a pipe and sucked on the side which goes to the carb - I am sucking air and a little bit of gas is getting into the fuel bowl - I would expect not to be able to suck air on that side as it should just suck up the gas from the line? took the top off the fuel pump but cannot see any split or anything. I guess if I take off the fuel line from the outlet of the pump to the carb and turn it over if no gas comes out pump is faulty?
Hope I can get a new diaphragm for this as they are very expensive.
lee
lee
