Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 2N transmission noise while moving
brian kohler
09-03-2013 14:05:26
which bearing? It makes the noise in the low forward gear range, but not the high forward gear range.
TheOldHokie
09-03-2013 17:53:39
 Re: 2N transmission noise while moving in reply to brian kohler, 09-03-2013 14:05:26
New info - you have an auxiliary transmission. If the sound goes away in high range but persists in low range sounds like it's in the auxiliary unit. AFAIK the only way to find out which bearing is to open it up.....
TOH
briankohler2005
10-11-2013 07:43:13
 Re: 2N transmission noise while moving in reply to TheOldHokie, 09-03-2013 17:53:39
Well, we pulled apart the 2n yesterday and found a chiped tooth in the sherman step-up drive and some bearings with spawling on them in it and the transmission. I have on order a bearing and seal kit for the transmission. My question is, it looks like some of the bearings have to be pressed on and off the shafts?? Is this correct and is it every bearing? The other question is, this tractor did sit for a while and I am finding some corrosion on about a 3 inch span of the 2nd and 3rd speed gears. It does not look terrable so will this smooth out or can I buy new gears? It seems like bearings and seals are no problem to find, but internal gears are a different story.
Copyright © 1997-2015 Yesterday's Tractor Co.
