Part Numbers for front mount 8N
ecar
Can anyone confirm the points and condenser are the same for either a front or side mount distributor?
I need to get a new set for a front mount 8N and I have the following NAPA part numbers:
FD-71 condenser
FD-6769X points
Are these correct?
here are front and side mount part numbers. take yer pic on what ya need:
NAPA Ford Tractor Part Numbers:
Front Mount distributor...
NAPA #CS35
Standard Ignition Blue Streak #FD-6769X (Premium)
Condensor:
NAPA #FA200
Standard Ignition #FD-71
Rotor:
NAPA #FA300
Standard Ignition #FD-104
Distributor Cap:
NAPA #FA350
Standard Ignition #FD-126
Coil IC670 (supposedly 6v, but check resistance or ask)
OEM style ballast resistor ICR40
Solenoid ECH ST540
Side-Mount Distributor:
NAPA #CS749
NAPA HEAVY DUTY PIERCED (ventilated) #CS753
Standard Ignition #FD-8081
Standard Ignition Blue Streak #FD-8081X (Premium)
Condensor:
NAPA #FA66
Standard Ignition #FD-75
Standard Ignition Blue Streak #FD75X (Premium)
Rotor:
NAPA #FA67
Standard Ignition #FD-108
Distributor Cap:
NAPA #FA352
Standard Ignition #FD-128
ecar........you ask "anyone confirm the points and condenser are the same for either a front or side mount distributor?"........NO! NOT the same .......the amazed Dell
Right numbers for a front mount, not the same for the side mount.
SoundGuy's got ya covered with the parts list if you can't find Standard Ignition brand.
