TractorLinks.com
Order Ford 8N Parts Online
Re: leveling gear box on 8n froze up
LDoyle
09-03-2013 12:03:46
Just to try to clarify which part I am talking about , the fork will spin on the screw shaft , it s the shaft that is froze up in the gear box . The shaft will not rotate . Hope I am explaining it clearly .
soundguy
09-03-2013 12:11:43
 Re: leveling gear box on 8n froze up in reply to LDoyle, 09-03-2013 12:03:46
advice didn't change any.
still cast steel to hard steel union. tapping, heat and penetrant.
LDoyle
09-03-2013 17:40:24
 Re: leveling gear box on 8n froze up in reply to soundguy, 09-03-2013 12:11:43
OK Thanks . I will try that . Do you know if when it does free up how you get it out ? Does the plug in the end of gear box come out ?
soundguy
09-03-2013 18:01:44
 Re: leveling gear box on 8n froze up in reply to LDoyle, 09-03-2013 17:40:24
to help you visualize it, hit the cnh parts site, pull up the exploded diagram of the leveling box. will be clear. alternately. if you have some versions o fthe f0-4 it will be in there. and in the MPC for sure.
and yeah.. 1 3/4" expansion plug atop it.
i think this link will take you right to the exploded diagram and parts list
LDoyle
09-03-2013 18:38:12
 Re: leveling gear box on 8n froze up in reply to soundguy, 09-03-2013 18:01:44
Thanks , that helps . It looks like there is a bearing assembly that is probably what is froze up and stuck on the shaft . I will try ya lls suggestions on freeing it up.
