off shore parts
47fivewindow
My brother rebuilt a small block chevy replacing the
front balance pully. Today we tried to start it.
Would you believe they cut the TDC mark 20 degrees
off? Expect anything.
Sure you didn't mix and match a pre-1978 or '79 timing cover and a post 1978 or '79 damper, or vice-versa? (The moved the timing pointer AND timing mark in that time-frame.)
Were liven the dream aint we!! Between cheap labor being called citizenship and loss of jobs to cheap and junk parts from the land of not even close, the 2 biggest bites out of our Republic. Its a done deal
