Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: More Questions on Oil Pressure
RumT
09-02-2013 10:56:24
If your clearances are excessive an oil pump that puts out advertised flow/pressure will only get you so far. An initial, less expensive, option may be to ensure you pressure relief valve is in serviceable shape. There are specs on the spring in some of the manuals.
TheOldHokie
09-02-2013 11:10:47
 Re: More Questions on Oil Pressure in reply to RumT, 09-02-2013 10:56:24
And what does that do to help the clearance problem? Running clearance in combination with engine speed and oil viscosity is what determines the thickness of the oil film inside the bearings. As clearances open up the oil film thickness is reduced - increasing pump pressure can't and won't fix that.
TOH
RumT
09-02-2013 12:14:44
 Re: More Questions on Oil Pressure in reply to TheOldHokie, 09-02-2013 11:10:47
Very good. You are so bent on arguing that you've failed to comprehend what folks are posting.
