TractorLinks.com
Show Parts for Model:
Re: Gas line issue or gas tank?
old
09-02-2013 10:53:15
The rubber line while it can work is not a good idea due to what most use a tractor for. I simple brake line with the correct ends is the better way to go and can be bent to work just fine and I have done many tractors that way and it works better then the rubber line will. The 2 minute run time is maybe a bad ignition switch. I would try hot wring it and see what happens. If it runs then you know the problem is in the ignition system from the coil back. If it does not run then the fuel so pull the drain plug and make sure you have a good steady flow of gas for say 5 minutes. Catch the gas to look for dirt water etc.
