Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: oil leak at distributor
DollarBill
08-28-2013 08:58:43
Dennis, the way your original post is worded we don't know if you are referring to the distributor or governor. Throw us a bone!
The governor doesn't bolt to the block and neither does the distributor - They attach to the timing gear cover.
If it's leaking where the governor meets the timing gear cover, it's likely the aluminum governor housing is warped due to being overtightened. To fix this, disassemble the governor and wet sand the mounting surface using a dead flat surface like a piece of Plexiglas. One of the governor bolts is longer than the other so pay attention where the bolts come from - Putting the longer bolt in the wrong hole will chew up the timing gear.
dennis8n
08-28-2013 10:36:08
 Re: oil leak at distributor in reply to DollarBill, 08-28-2013 08:58:43
i want and bought a manual it is the aluminum cover that is leaking ware it meats the block
Copyright © 1997-2015 Yesterday's Tractor Co.
