9n starting problems
me2havefun
New User
my 9n (6 volt) will not start. it will pull start in less then 5ft and runs fine when running. It turns over fast with starter.
try a jumper from batt. to coil..if it starts remove jumper..sometimes the coil doesn't get enough juice due to excessive draw from starter
Check all connections and ground between starter and block. Need a good ground there. Disconnect pto and hold clutch in when starting to reduce drag on clutch. HTH
DON TX
