Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Pistons in - how much drag is acceptable?
Charner MS
08-26-2013 15:15:01
Most all rebuilt engines are tight and some more than others. What I do is before I put the head on, I put a generous helping of lite old, 10w, and crank the engine about 30 second. Clean the oil and do it several times. That will seat the rings somewhat. Sometimes with a tight engine it will run hot until broke in. I remove the lower rad. hose and stick a water hose(sealing with a rag) in the lower rad. and fill the water chamber. Leave water on as it runs out the lower water outlet in the engine. Crank engine a run for and hour or so. After that it should be smooth.
