TractorLinks.com
Show Parts for Model:
Re: Front wheel
Hennessey
08-26-2013 15:02:05
I already have the tire, it is a 175/70R13. I need a rim. I would like to get one that matches the other. This one was flat and the rim was in contact with the ground and ruined it. Is this a common rim? They both look very old, about the same condition as the rear rims.
Ultradog MN
08-26-2013 15:25:06
 Re: Front wheel in reply to Hennessey, 08-26-2013 15:02:05
I have 14" rims on the front of my tractor that I bought new. They are standard implement rims which you can buy many places. I run cheesey little car tires on it - tubeless.
I did that to get the nose lower for mowing under trees, etc.
You can buy implement rims in 14, 15 and 16" dia and various widths.
But I have not seen 13" implement rims with the 6on6 (6 holes on a 6" bolt circle)
I am curious why you are trying to keep it 13"
You might have to cut the center out and weld it into a car rim. Did you look closely to see if that was done to the ones you have?
If you buy 14" you will have a lifetime supply of free/cheap used tires.
Hennessey
08-26-2013 16:23:44
 Re: Front wheel in reply to Ultradog MN, 08-26-2013 15:25:06
It had 13" when I bought it. The only reason I was looking for another 13; I did not want to buy two rims. So, if I have to buy a couple of rims do I just look for a 6on6 hole, 15" implement rims? Is the 4 5/8" center standard?
By the way, when you say 14 , 15, & 16" this is the same as the "R" number on a car tire, eg. if I get a 15" rim I can use an auto 215/65R15?
Randy-PA
08-27-2013 04:23:54
 Re: Front wheel in reply to Hennessey, 08-26-2013 16:23:44
Yes, if you buy 15" rims the 215/65R15 tire will fit. I bought 15"x6" implement wheels for my 8N and mounted 225/70R15 tires on them. I shopped around and got brand new rims for $55 each with free shipping.
