Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Front wheel
Ultradog MN
08-26-2013 13:58:31
What size tires are you planning to put on your tractor. 5X16 rim would be the most common.
You should be able to find some used ones pretty easy. Lots of guys here part out tractors to help pay for their hobby.
Hennessey
08-26-2013 15:02:05
 Re: Front wheel in reply to Ultradog MN, 08-26-2013 13:58:31
I already have the tire, it is a 175/70R13. I need a rim. I would like to get one that matches the other. This one was flat and the rim was in contact with the ground and ruined it. Is this a common rim? They both look very old, about the same condition as the rear rims.
Ultradog MN
08-26-2013 15:25:06
 Re: Front wheel in reply to Hennessey, 08-26-2013 15:02:05
I have 14" rims on the front of my tractor that I bought new. They are standard implement rims which you can buy many places. I run cheesey little car tires on it - tubeless.
I did that to get the nose lower for mowing under trees, etc.
You can buy implement rims in 14, 15 and 16" dia and various widths.
But I have not seen 13" implement rims with the 6on6 (6 holes on a 6" bolt circle)
I am curious why you are trying to keep it 13"
You might have to cut the center out and weld it into a car rim. Did you look closely to see if that was done to the ones you have?
If you buy 14" you will have a lifetime supply of free/cheap used tires.
Hennessey
08-26-2013 16:23:44
 Re: Front wheel in reply to Ultradog MN, 08-26-2013 15:25:06
It had 13" when I bought it. The only reason I was looking for another 13; I did not want to buy two rims. So, if I have to buy a couple of rims do I just look for a 6on6 hole, 15" implement rims? Is the 4 5/8" center standard?
By the way, when you say 14 , 15, & 16" this is the same as the "R" number on a car tire, eg. if I get a 15" rim I can use an auto 215/65R15?
Randy-PA
08-27-2013 04:23:54
 Re: Front wheel in reply to Hennessey, 08-26-2013 16:23:44
Yes, if you buy 15" rims the 215/65R15 tire will fit. I bought 15"x6" implement wheels for my 8N and mounted 225/70R15 tires on them. I shopped around and got brand new rims for $55 each with free shipping.
Copyright © 1997-2015 Yesterday's Tractor Co.
