Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: disking with a 8N
Indiana Ken
08-26-2013 04:36:22
The disc is used on the 3pt without a sway bar, you need the side to side movement to allow for turning. We used our 8N on the disc before dad bought another farm and we got a larger tractor. For tight turns you will need to lift the disc however we always made longer sweeping turns with the disc in the ground - in general the brakes should not be needed or used very lightly to turn. Brakes waste fuel.
Second gear is typically used with the plow, disc etc. - we always run at approximately 3/4 throttle. Some people would plow etc. at full throttle but dad never instructed us to run full open.
It is best to disc at an angle if you are going to make more than one pass. For example, we would disc a field from corner to corner and the second pass would be from the opposite corners at 90 degrees. Actually we would do, what dad called "two at once" ; the disc was not lifted once the field was started. I would need to post a diagram for explaination, if anyone is interested.
Glenn D
08-26-2013 08:41:50
 Re: disking with a 8N in reply to Indiana Ken, 08-26-2013 04:36:22
I'd like to see your diagram. going corner to corner sounds intersting
Indiana Ken
08-26-2013 20:13:05
 Re: disking with a 8N in reply to Glenn D, 08-26-2013 08:41:50
Sorry this is hard to read. My scanner will not read the document so I took a photo. See attached below.
There are four circles with numbers (1 - 4) in them on the diagram. The notes read as follows;
1) Start here (lower right hand corner), drop disc & drive north/west.
2) Lift disc to make turn.
3) Drop disc & drive south/east, all turns are made without lifting the disc except to start and finish.
4) Continue around & around, Finish passes will be south/west & north/east.
08-26-2013 20:37:19
 Re: disking with a 8N in reply to Indiana Ken, 08-26-2013 20:13:05
That's how I cut my grass.
08-27-2013 22:19:45
 Re: disking with a 8N in reply to ScoutB, 08-26-2013 20:37:19
What? you cut your grass with a disc? 8^)
9N 222933
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039
08-27-2013 23:28:32
 Re: disking with a 8N in reply to heybusdriver, 08-27-2013 22:19:45
heybusdriver said: (quoted from post at 23:19:45 08/27/13) What? you cut your grass with a disc? 8^)
actually? I've been using this.
click for bigger
thats what my field looked like in the early spring a few years ago when we got plentiful rains. actually, thats mayday, 2005.
the other pictures are what it looks like right now after a very dry winter.[/i]
This post was edited by pierce at 23:32:14 08/27/13.
