Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Front axle pin
54NAA
08-25-2013 14:38:32
My NAA has a one piece, non threaded pin. nothing threaded on the axle support. the axle does slide forward and aft when the radius rods are adjusted according to front wheel spacing.
TheOldHokie
08-25-2013 15:44:42
 Re: Front axle pin in reply to 54NAA, 08-25-2013 14:38:32
54NAA said: (quoted from post at 17:38:32 08/25/13) My NAA has a one piece, non threaded pin. nothing threaded on the axle support. the axle does slide forward and aft when the radius rods are adjusted according to front wheel spacing.
After checking the parts manual I stand corrected. The NAA used a different axle support but the same pin and spacer setup as the 8N. The threaded pin wasn't introduced until the Hundred series.
Looks like you need a replacement pin (NAA-3126A) and bushing (2N-3039). The NAA used spacers like the 8N but unlike the 8N they were all the thinner (.090) 8N-3027 spacers and were placed front and rear as required - roughly three needed according to the parts catalog. The radius rods were attached to the center axle section just like the 8N and did not move when the spacing was adjusted. If the radius rods are not attached to the center axle the tractor is likely farmerized using 9N/2N parts. I'm sure Don B would know exactly what combinations might have been used.
TOH
This post was edited by TheOldHokie at 15:47:57 08/25/13 2 times.
