Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Throttle Control Part 2
NevadaTim
08-24-2013 14:50:58
One more dumb question..
Should the spring on the governor be resisting the throttle handle pull through the entirety of the quadrant? If this is the case, my spring does not have any tension on it until I have fully opened the throttle on the carb.
JCinKY
09-19-2013 09:13:11
 Re: 8N Throttle Control Part 2 in reply to NevadaTim, 08-24-2013 14:50:58
NevadaTim said: (quoted from post at 14:50:58 08/24/13) One more dumb question..
A functioning governor with linkages attached properly should fight you as you open the throttle through the entire swing. The more you open the harder it should try to pull you back.
That said, hook everything up correctly. Now open the throttle by hand. You should feel good resistance from the governor trying to pull it back closed.
Preload is the amount of static force applied. In the springs case. With the governor just sitting there on the bench or installed with the throttle closed, the spring should be neither stretched nor compressed.
This post was edited by JCinKY at 09:15:04 09/19/13.
Copyright © 1997-2015 Yesterday's Tractor Co.
