Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 9N Parts Online
Re: 9N Differential???
08-23-2013 18:53:21
Remove the right inspection cover look at the coupler that couples the trans to the rear end... You can see the shafts it couples my money on is the coupler tube broke...
Removing the hydraulic cover would be a big waist of time because it would not be needed to be removed to repair any issue that would cause your problem... If you want to chase your tail and look like a fool remove the hydraulic cover...
08-23-2013 19:14:56
 Re: 9N Differential??? in reply to Hobo,NC, 08-23-2013 18:53:21
but because of the hole at the top / back of the center section cavity.. you can tell if the ring gear is spinning.. so it's not 100% useless. might make the difference between an axle or the ring gear.. if it aint the coupler or pinion.
and it's not hard to pull the cover anyway.. and just a cheap gasket.
