Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N Gas Leak at Carb
Bruce (VA)
08-23-2013 10:18:27
" I even used some pipe thread compound on the plug. "
Don't waste your time. It does not seal on the threads. It seals on the flare.
" Is it possible that I need to replace the brass inlet on the carb?"
Yes.
Don't honk down on it; it's brass. First, use a flare wrench to remove the fitting. (as in the picture) Next, if you do not have another fitting to screw into the elbow (as in the picture) then use a crescent wrench on the top & bottom (NOT the sides) of the elbow to remove it. Otherwise, you will distort it & you will never get the fuel line fitting back into it.
Acadianbob
08-23-2013 10:57:17
 Re: 8N Gas Leak at Carb in reply to Bruce (VA), 08-23-2013 10:18:27
Thank you Bruce. I would not have thought about what you just said. I got a new elbow/filter but I'll use your method to install it.
I did tighten the old elbow (the wrong way, on the sides) and may have deformed it as you point out.
