OT: spraying fence lines
I have fence lines to spray for weeds/vines/thorns with basically no saplings.
I have Remedy Ultra.
Could I mix like 2oz remedy, 2oz roundup to 1gal water with how much dish soap?
Any comments welcome regarding diesel too.
Rather not buy any more stuff like eraser, etc.
Greg
(quoted from post at 13:54:59 08/18/13) I have fence lines to spray for weeds/vines/thorns with basically no saplings.
Greg
I have been gun spraying fence lines and roadsides with glyphosate concentrate (43%) at 3oz per gallon of spray with nothing else in the mix and it kills any and all small brush it touches. Takes about 2 weeks to see first signs of wilt and total brown kill in 4+.
YMMV,
TOH
You real could just use remedy and water. I've used it with dish soap Ajax brand about 2 oz to 3 gallon sprayer. Last time I sprayed the chain link fence ... Over grown with poison ivy and some other vine, I used remedy and water and it worked very well. In a few weeks the top layer dried and started falling apart so I made a second past but the fence was badly neglected the vines where a foot thick.
Soap Miracle Grow and your choice ground sterilizer next spring after everything has a good start. Done
(quoted from post at 14:33:47 08/18/13)
Greg
YMMV,
TOH
I use Tractor Supply Brand of Ground Works with 50% Glyphosate..3oz per gallon of water..
http://www.external_link/en/store/groundworkreg;-50%-super-weed--grass-killer-40-fl-oz
I hate weed wacking fence lines!!!!
Had a fellow that used to spray fence lines where I worked with Roundup and he really put it to it. Fence rusted out in no time.
Richard
I use the generic roundup.....much cheaper than the name brand although I have not priced recently. Takes a bit more for the brush and tough stuff, but normally I can kill off a fence line with 2 oz per gallon of water, which is fairly inexpensive. I usually make one pass with my atv sprayer when no rain is predicted, then in a couple weeks I make another pass on what is left stil green. It takes a week or more before it starts to die off, and believe it or not, the dew seems to help the process.
generic round up 41 percent glyphosate
(quoted from post at 16:33:50 08/19/13) I use the generic roundup.....much cheaper than the name brand although I have not priced recently. Takes a bit more for the brush and tough stuff, but normally I can kill off a fence line with 2 oz per gallon of water, which is fairly inexpensive. I usually make one pass with my atv sprayer when no rain is predicted, then in a couple weeks I make another pass on what is left stil green. It takes a week or more before it starts to die off, and believe it or not, the dew seems to help the process.
Glyphosate is the ingredient that is the killer..Ground works is the only product that I have found that is 50% Glyphosate. I have used 11/2oz per gallon with good results..
