can'g front wheel outer bearing off
working on changing the two front tires.
Got the cotter pin out (it was a screw), the castle nut and the washer behind it off, but I can't get the outer bearing off.
Unless it's stuck badly to the spindle, put the tire back on, thread on a couple of lugnuts and "pop" the tire hard with the palm of your hand at 12 and 6, then 9 and 3.
NO, the outer bearing is a slip fit.If the bearing is shot it may have been turning on the spindle and worn a groove.
