Holding Stabilizer Bars between hookups
Thought this may help someone.
I carry a couple of spare pins meant for bolting onto an implement to hold up my stab bars between hookups.
Greg
I welded 2 quarter inch bolts on the outsides of the arms and just lay the stabilizer bars over them.
Richard in NW SC
That should work.
Drop them in the tool box when not in use.
I see you have a hydraulic top link on your tractor.
I think I know the answer to this (wink) but tell me, would you ever go back to a turnbuckle type top link?
I have those extra strong clinch pins and I put them (open) in the pin brackets on the lift arms and lay the sway bars over the lift arms to hold them off the ground - works well.
Shhhh! I'm trying to convince Joan that I need one tractor for each
implement because they're too hard to switch back and forth! ;)
Two pieces of hay twine or two loops cut from a small inner tube.Two worn out nylon dog collars or calf collars.
muffler clamp u-bolt upside down in the lynch pin holder on the lift arm if still there
like 36, I usually just use something laying around.
old short fan belts looped on themselves and taped together,
slip em on both arms. surprisingly, they don't fall off even on bumpy ground
