TractorLinks.com
Show Parts for Model:
Re: to replace or not to replace????
Bruce (VA)
08-13-2013 13:07:40
Amazing!
Pls post the stock numbers & I'll add them to the master list of part 3's.
Jock(OR)
08-13-2013 21:52:23
 Re: to replace or not to replace???? in reply to Bruce (VA), 08-13-2013 13:07:40
7mm wire core ignition wire is Belden 734803.
7mm Terminal, distributor end with two wings is Belden 727008.
7mm Terminal, "snap lock" 90 degree for spark plug end is Belden 727006.
7mm Terminal, "snap lock" straight for spark plug end is Belden 727005.
I didn't get the terminal boots, but they are also available. The older black ones may be harder to get. The local NAPA carries the red silicone boots for sure, but I didn't ask about the black ones.
redruff
08-13-2013 14:48:19
Just an FYI...
If you are rebuilding the water pump you have to do some pressing.
You have to press the old shaft out, the impellor on the new shaft and the new shaft into the bearings/housing.
I tore mine out only to find out I couldn't get it pressed until Monday.
Another option is the other site that is just8n's, they have a complete assembled unit including the pulley for not too much more.
