TractorLinks.com
Show Parts for Model:
Re: Leveling Box Question
DollarBill
08-13-2013 08:39:13
The bell crank is cast steel and I doubt you could bend it - You will likely find the lift height problem to be an adjustment or worn cam pin. Before you tear into it, remove the right side inspection cover and make sure the control valve is touching the pump housing with the quadrant lever at full lift.
carlntexas
08-13-2013 09:30:18
 Re: Leveling Box Question in reply to DollarBill, 08-13-2013 08:39:13
I did the cam pin and new naa piston last year, but I adjusted by the fo-4 manual. I know it's not adjusted right draft control doesn't even work. I've bought Zanes jig to get it right, but that still won't fix the leveling box from hitting on the trumpet.
