TractorLinks.com
Order Ford 8N Parts Online
Re: 12 volt conversion of '51 8n
oldtanker
08-12-2013 19:26:01
LOL, what Bruce isn't telling you is that with everything perfect in the system, fairly new fully charged 6 volt system will be difficult to start when it's -30F and the wind chill is bringing it down to -50F and the tractor sits outside. Heck old point systems factory 12 volts engines can be a bear to start in temps like that. My first vehicle was a 6 volt 51 Chevy truck followed by a 50 Chevy 4 door Deluxe. My dad helped me with those and he sounded a lot like Bruce and his "clean tight and bright". Even after rebuilding them both, no problems with the charging or ignition systems, both would have to be plugged in at about zero to pre heat the engine some. Dads AC CA with a good charging system, good engine and rebuilt magneto was a bear to start below about 10. That darned thing was so bad that dad just kept it plugged in when he wasn't using it because he needed it every day. My 8N didn't like anything below -10F. With the 12 volt it starts right up down to -25F (coldest it's been sense I converted. I'm sure the engine overhaul helped but now it pops right off.
Rick
Ultradog MN
08-13-2013 04:14:12
 Re: 12 volt conversion of '51 8n in reply to oldtanker, 08-12-2013 19:26:01
Well said.
The most vehement 6V advocates generally don't live above about the 40th parallel.
NoNewParts
08-13-2013 05:14:50
 Re: 12 volt conversion of '51 8n in reply to Ultradog MN, 08-13-2013 04:14:12
agree
while there are 6v'ers that will start in cold temps,
they are the exception, rather than the rule.
Most of mine get 12v, the few 6v ones I have start in warm weather fine........cold, I don't bother trying.
That, "make sure everything is right, hold your breath, don't mess up the fire/start attempt when it tries" gets old quick
really cold days, 12v, big CCA, big reserve, torpedo heaters,
knowing the tractors starting preferences, and not flubbing it...
and maybe...
As fellow Northerners know, taking off your gloves to 'work' on
something is just not possible some times in hard winter...you'll lose your fingers
(like the day my 07 truck's starter pulled the battery down so far, I lost my radio presets..it started though...did I attempt a tractor start that day?....nope)
to the OP, like said, 'trouble with the points' will be the same at any voltage, got to get that straightened out first
Hobo,NC
08-13-2013 05:10:08
And they are stuck with a P.O.S. front mount dist. that's a P.O.S. 6 are 12V's...
Side mounts were born to be converted 8) ...
