52fordredbelly
After putting a hole in the radiator of my 52 8n side mount I ordered some new parts from our hosts. The question is I decided to also order a new water pump since I was ordering in cooling parts anyway. There is nothing I know of wrong with the old pump but with no temp gauge I wouldn't know anyway unless I ran into a problem. The question is should I replace the one on it now and keep it as a backup or hold on to it until I have a good reason to change it. Some times it seems better to keep older parts in than replace. Also I forgot to order a set of new spark plug wires. I know tractor supply has some universal ones.. but is anyone aware of Advance Auto or Autozone (just because their closer) part numbers which would work. Not sure if they are the same metal core or not. As always thanks in advance for your thoughts.
