breaker plate
Why is it that parts are not made the same. Ordered a breaker plate and installed it and tried to put the gasket on that covers the points and it would"nt fit. The outside diameter of the bearing housing is larger than the center hole of the gasket I took out. I got to either enlarge the hole or find a new gasket that fits.
I just did the same thing with front mount distributor. The gasket went on the shaft and sat on top of the breaker plate housing. Put the rotor over that and it works fine.
Of course, I am assuming you are talking about a front mount distributor also.
Mark
It will go past the distributor shaft but won't go past the bearing housing. That prevents the gasket from going down where it shoul be.
