TractorLinks.com
Show Parts for Model:
Re: just when all was good...
Lisa K
08-11-2013 21:31:33
Hopefully we can get it done. What is the correct best seal to get? On a positive note some may remember I said it had no 2nd or 4th gear when shifting. Someone had bent the shift fork so it was impossible to use those gears. Removed it bent it back and have all 4 gears again. Hoe response is so much better also now that the white/caramel colored watery hydro fluid is gone in tank. Tranny fluid was awful also. Rear end had about a quart of what looked like used motor oil in it. . Certainly not 8quarts of anything! Some dipstick also swapped top covers so there was no fill place for the sump except beings the quadrant was not in place allowing water in we filled through there and will plug that hole and use as a fill spot. Odd thing clutch still worked great although oil soaked.
mhb@ufe
08-13-2013 05:25:55
 Re: just when all was good... in reply to Lisa K, 08-11-2013 21:31:33
The rubber seals are much easier to install than the rope seals.
