Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 12 volt conversion of '51 8n
old
08-11-2013 21:20:21
Big thing is that you do not need a 6 volt charge and a way to jump start it if switch to 12 volts. Plus if low on compression it will start on 12 volt but may not on 6 volts. Also if you need to tractor and it is say zero degrees out it is more likely to start. If done right points and all the other parts will last as long as if on 6 volts but starting can/will be easier
