TractorLinks.com
Order Ford 8N Parts Online
Re: 1952 8n w/ 12v generator
JMOR
07-28-2013 20:31:33
From what I can see of it, it has the outward appearance of an 8N10001 generator & probably stamped 12v because rebuilder changed out field coils & maybe armature to convert it to 12v. Any indication as to it being a 12v VR?
carltonwebb
08-02-2013 19:08:27
 Re: 1952 8n w/ 12v generator in reply to JMOR, 07-28-2013 20:31:33
Its friday so that means i returned home and worked with the tractor today after completing the other chores.
I got my box of parts and have everything installed except the proof meter b/c i wanted to wash the tractor first.
I got the key switch installed and everything seems to be working as it should. I have to remove the mystery headlight switch in the morning and wires and installed new wire to run headlights. It cranked in a half a turn with the new fuel line and carb gaskets. You can turn the throttle really low and it still will idle with that model a sound. The only thing i noticed is if you come down real fast with the throttle, it may hiccup and die sometimes.
I will look at other locations for s/n tomorrow as well
Back to the charging circuit, the voltage regulator is marked 12v. I did not get to go get another today but its pretty rusty and the tractor cuts off with the jump box removed. Will any 12 v voltage relay work?
There is no power to the generator wires. I just found how to test voltage regulator and going to do that in the morning. I have power going into the vr but nothing coming out.
This post was edited by carltonwebb at 19:09:01 08/02/13.
JMOR
08-02-2013 20:47:09
 Re: 1952 8n w/ 12v generator in reply to carltonwebb, 08-02-2013 19:08:27
There is no power to the generator wires. I just found how to test voltage regulator and going to do that in the morning. I have power going into the vr but nothing coming out.[/quote:6378080941]No, not any 12v voltage regulator will work. If your generator is, as was the original, the TYPE_A unit, then it must uses a TYPE_A VR. If it is a TYPE_B unit then it must use a TYPE_B VR.
carltonwebb
08-03-2013 18:38:16
 Re: 1952 8n w/ 12v generator in reply to JMOR, 08-02-2013 20:47:09
Before doing the charging tests, I took the meter and checked the large termininal to ground. It had only 50 ohms resistance. According to the test procedure i found, if you hook the batt term to the arm terminal at the VR, it should increase in voltage which it did not. It dropped in voltage and the big terminal got warm to the touch. I am going to take it back to the local rebuilder this week and have him go through it.
Its unreal how much oil psi this tractor has. The new gauge they sent me only goes to 60 psi. The old one that did not work was an 80 psi. It will max out the gauge with oil psi at full throttle, even hot.
All the gears work as they should. The clutch may be a little weak but its been a while since i have been on a total mechanical clutch. The left brake works ok. The right brake does not work at all. I will have to check into that. With the new proofmeter installed, it will idle all the way down to around 350 with that model a sound.
Tomorrow is lift day. I bought a psi relief valve to put in. The lift will raise really fast until it gets the weight of the bushhog on it and it stops. Hopefully, the relief valve will fix it but I will look in there for leaks tomorrow.
My s/n is 8n432061 with stars on each end. I did look at that but it got dark before i made it to the other locations to look.
This post was edited by carltonwebb at 18:41:40 08/03/13 2 times.
