TractorLinks.com
Order Ford 8N Parts Online
Re: 1952 8n w/ 12v generator
carltonwebb
07-28-2013 13:24:04
http://s1322.photobucket.com/user/Carlton_Webb/library/8n
i think you may be right. Today i took the carb off and cleaned it up. It has he marvel carb on it still. I need to get the internal bowl gasket for it but i did put it back together and it runs better. The tag on the side of it where the pin for to choke butterfly has a 49 on it. I as able to get the s/n an found it to be 8n432061 which i think makes it a 51. It does have the proof meter dash. I am going to recheck s/n in a littlebit and make sure the 3 is not really an 8. I am not sure about the lift arms so i posted that pic too.
I think you are right about the switch. I have power to the batt wire now on the regulator. The switch has a wire that comes off it and goes to the black wire on the generator. I posted a pic of it and there is also a link in this reply. I have not washed the tractor and have been scared to run it too much until i get the new fuel line for the carb. Leaking right on top of engine and exhaust. I do not know if it will show up in the pics but they Generator has a stamp of NTP on it and then 07. That is the stamp of a local rebuilder and where i would have taken it to have it built.
In your experience, would you say if it tries to lift and stops with the weight of the load, it is prob the cylinder? I figured once i got it running, i would pull the side covers and check for leaks but one thing at a time. I just like to think ahead.
The only other thing i am second guessing myself on is I have this hooked up as a neg ground 12v. I think this is correct but would anyone disagree?[/img]
This post was edited by carltonwebb at 13:27:31 07/28/13 3 times.
JMOR
07-28-2013 13:52:04
 Re: 1952 8n w/ 12v generator in reply to carltonwebb, 07-28-2013 13:24:04
I see the NTP marking on the generator but not the 12v marking? Pos or neg ground? It came from factory as POS ground, BUT it is clearly not "factory" with 12v battery & generator and whether 6v or 12v, it is a simple matter of swapping battery cables & polarizing the generator & reversing ammeter to make all function just as well either way. Some would throw in 'reverse coil' too, but that is a "don't care" as it runs the same either way.
Also, you say, "The switch has a wire that comes off it and goes to the black wire on the generator.". The black wire on gen is generator case ground. A switch typically has 2 wires or more, so what about the other switch wire?
This post was edited by JMOR at 14:18:06 07/28/13.
carltonwebb
07-28-2013 14:33:43
 Re: 1952 8n w/ 12v generator in reply to JMOR, 07-28-2013 13:52:04
I came back to edit it. Originally, i thought they were using the original headlight switch location for the ignition switch. The mystery switch in the proofmeter hole must be for headlights which i do not have right now. I traced the wires again and they go to across the top of the engine and then to each side where the headlight should mount. Its strapped to the same wires as the generator. It is a different gauge wire than the black one on the generator. That is the only cobbled up mess on it. I think next weekend when i get back, i will pull the hood completely off. It will allow me to get all the acorns and straw out of there and see all the wires really well. The voltage regulator has ants coming out of it so I think it is probably toast.
I am going to order the parts i know i need tonight (fuel line, carb gasket, oil filler cap etc) and I hope they will be here by next friday and i can actually drive it across the field.
I will get a better pic of the markings on the gen and add it to the album. I cannot get the fuel to completely shutoff with the valve so I guess i will look at getting a replacement fuel shutoff too. It would not be that big of deal if it were not for the pin hole in the fuel line.
This post was edited by carltonwebb at 14:35:58 07/28/13 2 times.
carltonwebb
07-28-2013 20:10:58
 Re: 1952 8n w/ 12v generator in reply to carltonwebb, 07-28-2013 14:33:43
i added the gen marking picture to the original album.
It says:
NTP "nash truck parts=local rebuilder"
007 "2007"
12v.
It is completely possible all it is wrong is the regulator or i missed a wire. The black wire in the middle of that picture is the one i pulled down when tracing the mystery switch that should go the headlight. The mystery switch as 3 wires on it-b+, common and ground for the light in the switch. It is one of the rocker type switches with the light in it like a wrecker would have to show you its on.
This post was edited by carltonwebb at 20:14:21 07/28/13.
JMOR
07-28-2013 20:31:33
 Re: 1952 8n w/ 12v generator in reply to carltonwebb, 07-28-2013 20:10:58
From what I can see of it, it has the outward appearance of an 8N10001 generator & probably stamped 12v because rebuilder changed out field coils & maybe armature to convert it to 12v. Any indication as to it being a 12v VR?
carltonwebb
08-02-2013 19:08:27
 Re: 1952 8n w/ 12v generator in reply to JMOR, 07-28-2013 20:31:33
Its friday so that means i returned home and worked with the tractor today after completing the other chores.
I got my box of parts and have everything installed except the proof meter b/c i wanted to wash the tractor first.
I got the key switch installed and everything seems to be working as it should. I have to remove the mystery headlight switch in the morning and wires and installed new wire to run headlights. It cranked in a half a turn with the new fuel line and carb gaskets. You can turn the throttle really low and it still will idle with that model a sound. The only thing i noticed is if you come down real fast with the throttle, it may hiccup and die sometimes.
I will look at other locations for s/n tomorrow as well
Back to the charging circuit, the voltage regulator is marked 12v. I did not get to go get another today but its pretty rusty and the tractor cuts off with the jump box removed. Will any 12 v voltage relay work?
There is no power to the generator wires. I just found how to test voltage regulator and going to do that in the morning. I have power going into the vr but nothing coming out.
This post was edited by carltonwebb at 19:09:01 08/02/13.
JMOR
08-02-2013 20:47:09
 Re: 1952 8n w/ 12v generator in reply to carltonwebb, 08-02-2013 19:08:27
There is no power to the generator wires. I just found how to test voltage regulator and going to do that in the morning. I have power going into the vr but nothing coming out.[/quote:6378080941]No, not any 12v voltage regulator will work. If your generator is, as was the original, the TYPE_A unit, then it must uses a TYPE_A VR. If it is a TYPE_B unit then it must use a TYPE_B VR.
carltonwebb
08-03-2013 18:38:16
 Re: 1952 8n w/ 12v generator in reply to JMOR, 08-02-2013 20:47:09
Before doing the charging tests, I took the meter and checked the large termininal to ground. It had only 50 ohms resistance. According to the test procedure i found, if you hook the batt term to the arm terminal at the VR, it should increase in voltage which it did not. It dropped in voltage and the big terminal got warm to the touch. I am going to take it back to the local rebuilder this week and have him go through it.
Its unreal how much oil psi this tractor has. The new gauge they sent me only goes to 60 psi. The old one that did not work was an 80 psi. It will max out the gauge with oil psi at full throttle, even hot.
All the gears work as they should. The clutch may be a little weak but its been a while since i have been on a total mechanical clutch. The left brake works ok. The right brake does not work at all. I will have to check into that. With the new proofmeter installed, it will idle all the way down to around 350 with that model a sound.
Tomorrow is lift day. I bought a psi relief valve to put in. The lift will raise really fast until it gets the weight of the bushhog on it and it stops. Hopefully, the relief valve will fix it but I will look in there for leaks tomorrow.
My s/n is 8n432061 with stars on each end. I did look at that but it got dark before i made it to the other locations to look.
This post was edited by carltonwebb at 18:41:40 08/03/13 2 times.
