TractorLinks.com
Show Parts for Model:
Re: PTO Seal and other
DollarBill
07-26-2013 01:26:32
The PTO shaft has an enlarged section where the seal contacts the shaft.
Simplest way to stop your steering box seals from leaking is to replace the gear oil with corn head grease.
Optimally you would remove the gear box and drain all of the oil but that's a lot of work - As the CHG and gear oil are petro based you don't necessarily need to remove the gear oil, just install a Zerk fitting and pump in the CHG until it comes out the steering box tube beneath the steering wheel. Maybe a little messier doing it this way but it's faster and easier than removing the gear box.
patsdeere
07-26-2013 10:17:16
 Re: PTO Seal and other in reply to DollarBill, 07-26-2013 01:26:32
Thanks for the info.
George Marsh
07-26-2013 09:13:51
I filled 2 tractors with grease, no problem.
