Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 47 8n front dist
Tom vertiz
07-25-2013 19:49:47
I had that same problem. Turned out that the interior of the distributer was pushed up out of the groove it is supposed to be in. There is a wire snap ring that holds the whole assembly in and it was out of its groove. When I put the coil on it would ground out. I put the dist on without the cap and just finger tight the bolts. You can turn the rotor by hand and you will deffenitly feel when it is in the correct spot. Then I hook up the cap and coil. I know other people do it as a whole assembly but I had better luck like this.
Tom vertiz
07-25-2013 19:54:26
 Re: 47 8n front dist in reply to Tom vertiz, 07-25-2013 19:49:47
Actually now that I read your post a little more carefully I realize my problem was a little different than yours. Hope you get it going.
