TractorLinks.com
Show Parts for Model:
Re: 601 12v conversion
old
07-25-2013 07:27:17
Never have and never will use a lit since most are 1 wires. I buy an alternator made to fit a 1980 Chev pick up no power any thing no AC cost is around $45 with a life time warranty at O'Reilly's. Some wire 10 and 12 gauge and a plug for the 2 prong plug and a Radio shack diode 276-1661
redruff
07-25-2013 08:13:41
 Re: 601 12v conversion in reply to old, 07-25-2013 07:27:17
Can you point me toward directions?
I looked at JMOR'S schematics but nothing for the 601.
You happen to have a part number on the alt.?
What do you do for the mounting bracket?
soundguy
07-25-2013 16:40:22
 Re: 601 12v conversion in reply to redruff, 07-25-2013 08:13:41
if you an't come up with your own brackets ( make them ).. then get the kit.. i'd get a new 12v coil.. napa ic14sb.
i'm not a fan of 1 wire alts.. some are. if you get a 1 wire.. see if it will run like a 3 wire.
redruff
07-25-2013 07:36:55
old
07-25-2013 07:56:09
 Re: 601 12v conversion in reply to redruff, 07-25-2013 07:36:55
Do not have the part number for the alternator that is why I said 1980 Chev pick up guess should add 350 engine to that . LOL As for the bracket most of the time I use a piece of all tread rod and on some you flip the bracket over that held the generator and set the alternator in front. Any diagram for an alternator is the same be it for an 8N or a 601 only different is the tractor but the alternator still wires up the same. I can pretty much do them in my sleep but have done hundreds of them over the years
redruff
07-25-2013 08:06:43
 Re: 601 12v conversion in reply to old, 07-25-2013 07:56:09
Sorta figured that on diagram, I was just concerned about the dash light, etc. But I think JMOR has a diagram with the extra lights, etc.
rvirgil_KS
07-25-2013 11:37:30
 Re: 601 12v conversion in reply to redruff, 07-25-2013 08:06:43
Switch end of dash light stays connected. Take regulator end of dash light wire and connect to #1 pin on Delco 3 wire alternator. Connect #2 pin to big output stud on alternator.
Dash light will not work with one wire alternator
