TractorLinks.com
Show Parts for Model:
Re: OT - I Did It Again - Yep, Another Farm Accident...
ZANE
07-15-2013 05:49:55
Sure glad that thing didn't hit you in one of them articles as one of my helper friends said when that happened to another friend while knocking out a master pin from a dozier track with two big hammers.
The best way to change the sections in a sickle blade is to remove it from the machine and place each section down in a vice that is closed almost tight with the blade back pointing up and just strike the section with a big hammer to shear out the rivets. Easy as pie and no danger unless you hit a finger. Helps to have a helper hold the blade in the vice. I bet I've knocked out at least a thousand secitons that way. An old farmer showed me how to do it years ago when I was working in the Ford dealership.
Zane
Royse
07-15-2013 20:54:50
 Re: OT - I Did It Again - Yep, Another Farm Accident... in reply to ZANE, 07-15-2013 05:49:55
That's the way my dad taught me too.
Still using our JD #37 sickle mower. (this past weekend in fact)
Still changing sections (we called them knives) the same way.
old
07-15-2013 07:55:23
The owners manual I have for a Ford 515 sickle mower say to do it the way your talking abut. Works great. Me I cheat any more I use the bolts to replace the old pain in the back side rivets and that way can change a section out in the field in less then 5 minutes and be back up and running fast
JMOR
07-15-2013 07:23:35
Quoting Removed, click Modern View to seeZane, my Dad used that method & it did work real slick.
