Ok, so my tractor quit while having just started it and driving it about 130 feet. Engine was ambient temp., about 80F, and wasn"t used that day at all.
Multi-meter shows battery voltage at the terminal. Pulled a wire off a plug and put a known good plug to check spark and grounded to another plug left in the head. No spark AT ALL. I am assuming this will be a bad coil. Ok, I checked the ohms on the coil and they are 1.35.
BTW, this is a front mount 6v square can and the motor turns over as fast as it should, just no spark.
I have a relatively new 6v battery. Should I bark up the 12v coil tree? I am thinking I would need to change the battery to a 12v also then.
Any help is welcomed.
