TractorLinks.com
Order Ford 8N Parts Online
Re: 8n ignition
award
07-14-2013 18:40:53
I assume the other end of the test light goes to the (-) on the battery.
I'll do this tomorrow. On a side note I'll have to get some new 8-32 x 3/16 screws for inside the distributor. I have very little time running it since I changed points and I seem to recall that while setting the points ... the maximum I could set them was what is called for and no more.
36 coupe
07-15-2013 02:26:16
 Re: 8n ignition in reply to award, 07-14-2013 18:40:53
You assume wrong.The clip has to go to the tractor ground, positive terminal of battery.You better forget the 12 volt bit.The adjusting screw is actually a rivet.You need a lock washer on the screw that holds the point setting.
