TractorLinks.com
Show Parts for Model:
Re: fluids
JCinKY
07-14-2013 14:37:25
Trans, rear end, lift is all one common sump. Start with the small pipe plug so you can aim it into a 5gal bucket.
The 2" plug will let it all out in about .2 sec.
Should be a dipstick in the inspection cover by your right heal.
Fill it up by the start button on the shifter cover. Rated capacity is 5 gal, but it'll probably only hold 4.5 if it hasn't been cleaned in awhile.
Use any hy/tran fluid that meets Ford 134 spec. Lots prefer traveller brand. Fill until its on the stick, or take the bottom bolt out on the same cover and fill til it just leaks out.
roadteck
07-14-2013 14:58:32
 Re: fluids in reply to JCinKY, 07-14-2013 14:37:25
thanks for help
roadteck
07-14-2013 15:06:24
 Re: fluids in reply to roadteck, 07-14-2013 14:58:32
have two big drain plugs and 1 small
1 big one under trans. 1 big one in middle about where lift dip stick is and small one under rear end are you saying same fluid in everything ? and to drain from small plug under rear end ?
JCinKY
07-14-2013 15:17:43
 Re: fluids in reply to roadteck, 07-14-2013 15:06:24
Same fluid in everything, they're all connected.
Let the majority of the fluid out through the small one and then remove all of them. It'll be cleaner that way. 1 big plug to drain trans, 1 big plug for pump, small pipe plug for rear end.
roadteck
07-14-2013 15:38:33
 Re: fluids in reply to JCinKY, 07-14-2013 15:17:43
ok thanks got ya
