Wheel Bolt Pattern
Fronts will and if it has the 6 loop rims on the back those will switch out also
I'm pretty certain they wont.
2910 had a much heavier, double reduction rear axle. I don't know why they used such overkill on a 36 hp tractor but...
The rear bolt/lug nut pattern on a 2910 should be 8 on 8" instead of the 8 on 6" found on most of the smaller Fords from the 8Ns through 1982 or so 3600s.
I could be wrong but I would ask the seller to measure the bolt circle for you before running off on a wild goose chase.
FYI the seller returned my call. Fronts would work but his turf tire rear wheels are 8 lug 8 in pattern NAA is 8 lug 6 in pattern That sux:(
