TractorLinks.com
Order Ford 9N Parts Online
Re: ford 9n has no spark!!! 6 volt system
chuck0794
07-08-2013 20:38:34
Made some headway. I pulled the distributor out and tested it for spark on the bench. Plugs were sparking when I turned it manually. Installed on tractor and no spark. Found my ammeter must be giving me grounding issues. I ran a wire directly from the coil to the negative side of battery just to try it. It started right up. I removed the wire immediately. I noticed the ammeter was sparking through the window gauge. Once I shut the tractor off it started up without the wire jumper. The next time it would not start. Is this something common with this gauge???
JMOR
07-08-2013 21:08:27
 Re: ford 9n has no spark!!! 6 volt system in reply to chuck0794, 07-08-2013 20:38:34
Quoting Removed, click Modern View to seeObviously not the original "loop" ammeter.......it would never spark inside. So, just replace the already once-replaced ammeter & get on with tractoring.
