Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: replacing solenoid on 12v 8n
07-08-2013 05:49:29
the 4 posts solenoids on the 01 series are isolated coil and work fine with the thumb tranny switches.
key on provides power to the coil, thumb button grounds it.
36 coupe
07-08-2013 15:31:34
 Re: replacing solenoid on 12v 8n in reply to soundguy, 07-08-2013 05:49:29
This is a good system because it keeps kids from playing with the starter button.My f150 has a diode across the coil to keep voltage spikes out of the computer.
07-09-2013 06:17:32
 Re: replacing solenoid on 12v 8n in reply to 36 coupe, 07-08-2013 15:31:34
i used to get intot he habit of putting diode protection across all the lil relays and such that i had on vehicles back when ECU electronics were a lil less robust.
07-08-2013 06:16:36
Quoting Removed, click Modern View to seeIn response to 36coupe, it is as sounDguy says........but the problem arises when the 4 post unit is NOT an isolated coil type solenoid AND this happes more often than not, because so many cars/trucks used a non-isolated coil unit with the 4th post being utilized to power the ignition coil during start-up. So this latter unit, being so very common, is what the counter jockey hands you at the auto parts house when you ask for a 4 terminal solenoid. Look same, marked same "S" &"I", but not right for a 'starter safety' interlocked tractor.
