Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 8N Parts Online
Re: 8N transmission locked up.
Royse
07-07-2013 15:47:59
I've not had that problem, so I'm speculating here.
You say the engine will only turn 1/2 of a revolution?
Is that with the clutch engaged or disengaged? Both?
If the engine won't turn on it's own, probably not just a tranny problem.
Another thought, specially if it only does that when the clutch is engaged
and while you still have the tranny cover off, have you checked for a broken gear?
hotdawg22
07-07-2013 20:24:34
 Re: 8N transmission locked up. in reply to Royse, 07-07-2013 15:47:59
OK. I think i might have answered this but here again. I did try to turn engine without engaged clutch and engine spun freely. Let clutch out and it actually turns less the 1/2 turn in either direction and locks up. Took out the forks and made sure the slide were not in 2 gears and still the same thing.
Suspected that a broken tooth lodged in the cogs was to blame but discounted that when it locks in both directions, highly unlikely that broken tooth metal is lodged in two places causing the same block in both directions???
