FLOLDFORD
- Location
- Lakeland Florida
Need the experts opinions on this one. Im in the process of putting a 8n 6 cylinder back together and started it up on stands today for the first time since I tore it down over a year ago. everything work fine except the lift it does nothing at all ( yes the PTO was engaged ) What do you think is the relief valve stuck are could it be something else. Lift worked fine before I tore the tractor down to repaint it. Haven't touched the hyd. system but that's about the only thing that I didn't work on. Really hate to start tearing it back apart after its been painted but if I have to so be it. Its sitting on stands with no sheet metal on it yet so at least I didn't have it completely back together before I found this problem
