Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: OT 2000 Buick
RobertWork
07-07-2013 05:00:27
IF it is your inner CV joint you should replace the whole axle assembly. These usually cost about $125-150. They can be checked visually by jacking the car up and inspecting the rubber boots and then giving each end of the axle a good hard shake. Not a foolproof method but should give you some idea of condition. If it is bad enough to cause vibration, it should show a bit of movement when you grab the axle and try to move it back and forth. If no movement and the boots are intact, check other things, like worn struts.
Phlash in OK
07-07-2013 05:11:52
 Re: OT 2000 Buick in reply to RobertWork, 07-07-2013 05:00:27
Thanks for the info, I'll check it out
