I bought an 8 n that had the transmission locked in 2 gears and got it unlocked, i thought, by moving engine backwards and it seemed to work cause i could then get the shifting arms back in neutral position.
I tried to rock the tractor and discovered it was still locked up and will not move although all gears are in neutral.
I suspect the rear end is locked up.
Question is... could the rear end be locked up and how do i unlock it. Also, how can this happen.
