8n differential locked up
hotdawg23
New User
I bought an 8 n that had the transmission locked in 2 gears and got it unlocked, i thought, by moving engine backwards and it seemed to work cause i could then get the shifting arms back in neutral position.
I tried to rock the tractor and discovered it was still locked up and will not move although all gears are in neutral.
I suspect the rear end is locked up.
Question is... could the rear end be locked up and how do i unlock it. Also, how can this happen.
Jack up the rear end on both sides. Then try to turn one wheel does not matter which way. The one you turn should not go the same way as the other one if you do not have a problem.
