industrial tractor id help
960man
New User
my dad just brought in a yellow ford industrial with ford loader and hoe on it.trying to decode numbers and dont know for sure what some of the numbers mean.the numbers are k5011k , 4f18b , c430850. loader number 19-6380 , CL04009 and hoe number 19-389 , CB02873.i"ve come up with (K)unknown(50)industrial(1)diesel(1)no pto(K)6/4 manual reverse.(4)1974(F)june(18)day(B)day shift.need help on the first K and what is a 6/4 manual reverse?
6/4 means 6 speeds forward= 3 hi, 3 lo. 4 means 4 reverse speeds= 2 in lo and 2 in hi. Manual is self explanatory.
The C in the serial number indicates it's a 3000 chassis (c430850) so it's probably a 3400.
It should have the smaller, square axles and single reduction rear end. Same tractor as a 3000 in all regards except the front axle.
3400 was the smallest unit you could buy as a factory TLB.
Those 19-XXX numbers are the old system of Ford numbering - actually date back to the Dearborn days. Still helpful for ordering parts from CNH though. Most people will refer to things by the newer numbers if you can find them. Loader would start with 7 like 720 or some such. Likely just painted on the unit.
CNH shows 19-389 to be a 15" auto dig back hoe - used on a 3400.
I don't know what the first K in the model # is either. (k5011k) Are you sure it's a K and not an <font size="4.5" color="black">*</font>?
You should ask the folks on the Ford Board.
Guys like Sean PA are very knowledgeable about those numbers.
The gurus here are quite good at helping you put points in a 6V 8N but not much help with Fords beyond that.
That 6X4 was kind of odd but good for loader work where you were doing a lot of back and forth driving. I put one in a 2000 with a blown tranny and then sold it. The pic below is of the shift pattern on them if that helps.
I wrote the pattern on the dash with a sharpie so I - and the new owner - could remember it.
thanks ultradog on the info.your very keen on this stuff.i'll recheck my numbers for everything and get back to the correct ford board.
