Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: replacing solenoid on 12v 8n
R Geiger
07-06-2013 14:40:14
8Ns use a three post solenoid. small post is provided a ground by the saftey starter switch on top of trans. small terminal goes towards engine. 4 post , I have no clue how it was wired. You see all knids of set ups after 60 years.
DJ Schmidt
07-06-2013 15:10:30
 Re: replacing solenoid on 12v 8n in reply to R Geiger, 07-06-2013 14:40:14
It's also an aftermarket key-type ignition switch, just like a car's . The old solenoid was a 4-post.
07-06-2013 16:52:16
 Re: replacing solenoid on 12v 8n in reply to DJ Schmidt, 07-06-2013 15:10:30
oe key switch is 2 terminal, on / off.. just controll signition.
oe solenoid was 3 terminal. safety interlocked thumb switch on the trans top grounds the 3rd terminal and actuates the solenoid..
i do not advise a key to start auto setup that bypasses the safety interlock start feature your tractor was made with.
DJ Schmidt
07-09-2013 14:37:55
 Re: replacing solenoid on 12v 8n in reply to soundguy, 07-06-2013 16:52:16
Okay, now bought a 3-post solenoid; connected the 'BAT' terminal directly to the battery cable and to one side of the key-switch; small terminal to the other side of the switch; third terminal to starter positive terminal. Still, no go. Have bench-tested starter: it spins and retracts the "Bendix" apparatus. Odd thing is, it has started and ran(for no apparent reason) twice in the last week.
07-09-2013 15:19:40
 Re: replacing solenoid on 12v 8n in reply to DJ Schmidt, 07-09-2013 14:37:55
remember. your on/of 2 wire ignition switch just controls power to the IGNITION!
07-09-2013 15:17:37
incorrect wireing!
the small 3rd terminal on an oem 8n solenoid goes to the GROUNDING SWITCH on the top of the tranny.
