9n frontend alignment
I'm needing some help guys. My father was brushhogging the other day and got a little to close to one of the trees out in the pasture. the front right side tire hit the tree, the result was the left side tire was facing straight ahead and right side tire turning right. any help with this would be greatly appreciated.
You popped the steering gear out of time in the steering box.
Try loosening the bolts that bolt the top half of the steering box from the tranny cover and see if you can get it back into time.
No need to disconnect the steering box. Just disconnect the drag links and retime the steering. Move the left arm all the way to the rear and the right arm all the way forward then bring back to the center to retime the steering.
