8n stalls out after 15 minutes - carb not getting fuel?
cersbo
New User
after operating 15 minutes, full throttle on highway in 4th gear, tractor stalls out. It will start with choke wide open but sputters. I have to rapidly open/close the choke just keep it idling. after cooling down seems to run ok. I am not very mechanical but it seems like it is heat and fuel related as opposed to electrical. Any thoughts greatly appreciated.
"carb not getting fuel?"
Only you can answer that question. We can only guess. Immediately when the tractor runs rough get down and check for spark. Lots of post here on how to do that. Then check for fuel by removing the pipe plug at the bottom of the carb and catching gas in a clean container. Should flow about a pint a minute without slacking.
Could be electrical or fuel. I check spark first b/c it's quick and easy. Fuel next if blue spark shows. I suspect ignition switch first. Jump the switch if weak/no spark. I go thru 1-2 switches a year. HTH
DON TX
cersbo........you do know enriched mixture by pumping yer spring loaded choke knob is eazier to sparkle with weak sparkies, don't you???
Our experience sez 15-mins is typical time fer weaksister ignition switch to cause weak sparkies and ruff running and stalling. After cool down of about 30-mins, ignition switch is good-to-go fer nutter 15-mins of eazy runnin'
Keep yer itchy-twitchy fingers off'n them handy-dandy carb tweek'ums. They ain't-chur problem.
BTW, about 1-mins of runtime and stalling out is BAD condenser. NOT yer problem.
About 5-mins of runtime is CLOGGED in-the-tank fuel filter. NOT yer problem.
It takes about 1-hr of running fer yer 1-terminal squarecan ignition coil to cause weak sparkies. NOT yer problem.
As said, 15-mins of runtime is BAD weaksister ignition switch. Do I haffta tell you to replace it??? ........Dell, yer self-appointed sparkie-meister
As R Geiger asked.....it is important for you to tell us if your tractor has a 6 volt or 12 volt electrical system & if the distributor is on the front of the engine or on the side. The troubleshooting is different based upon the configuration of your engine.
And as Don & Harold both said, you could easily have a spark or fuel problem. We can't tell you which it is, but we can tell you how to find out.
It takes three things for an engine to run: spark at the right time, compression, & fuel in the right mixture. For the moment, forget about compression & concentrate on narrowing the problem down to spark or fuel.
There are three very important tools you always need to have in your N tool box: a 3 inch piece of wire w/ alligator clips on each end, an old spark plug w/ the gap opened to at least 3/16” ( ¼” is better) and a 7/16 box end wrench. (see tip # 50 at the link below) And, you really do need a working ammeter on the tractor; it is a very important diagnostic tool. With these tools, you can quickly narrow down most N problems to spark or fuel.
Next time it stops, check quickly for fuel then spark. When I say quickly, I mean get off the seat, grab the tools & do it right then. Do not wait a minute or two. First, check for fuel. Get a can & put it under the carb. Remove the bolt in the bottom of the carb; as long as the fuel is turned on, you should see gas flowing out of the carb. Let it run for at least 30 seconds. If it’s a dribble, or runs for 5 seconds & stops, or none at all, you have solved half the problem: it’s fuel related. If gas flows well out of the carb & only stops when you turn it off at the sediment bowl, chances are very good it’s not a fuel problem. So, next, turn the key on, crank the engine & look at the ammeter. What is the needle doing? Does it show a constant discharge, no movement at all, or does it move back & forth slightly? Next, get the old plug, ground it to a rust & paint free spot on the engine, turn the key on & crank the engine. If the spark jumps the 3/16” gap, you probably don’t have a spark problem. If it won’t jump the 3/16” gap, you have a spark problem. If the ammeter needle shows a constant discharge, or doesn’t move at all, that also tells you that you have a spark problem. Jump the ignition switch w/ your jumper wire & see what happens. If it runs, you found the problem. If it doesn’t have spark after you jump the ignition switch, post back for more info on further troubleshooting. (and do not forget to turn the ignition switch off; see tip # 38)
If it does not have gas coming out of the carb at a steady stream w/ the bolt out for at least 30 seconds, you have a fuel problem. First, remove the gas cap. Your vent could be clogged & it vacuum locked. If that doesn’t work, tap the carb bowl w/ a hammer handle in case the float is sticking closed. (don’t whack it w/ the head of the hammer; you can crack the bowl). If you still don’t see gas flowing, the N has three fuel screens; one in the brass elbow, one in the top of the sediment bowl & one on the stem of the sediment bowl in the gas tank. Check the screen in the elbow & the screen in the top of the sediment bowl. (don’t worry about the one in the tank) Both probably need to be cleaned. If you have the fuel knob turned on all the way, & 1 gallon or less in the tank, it may be trying to feed off of the reserve inlet which is probably clogged. Only open it 2 full turns. Put at least 2 gallons in the tank. (and do not forget to turn the gas off; see tip # 9)
There are ways to check for spark & fuel that work & ways that don't. For example, having gas to the carb is nice, but having it past the float is what counts! That’s why removing the 7/16” bolt in the bottom of the carb is the way to check for fuel. And, same thing w/ spark at the plugs. Some folks think that checking for spark means pulling a plug wire off & looking for one. Well, it's the distance the spark jumps at the plug that gives you the info you want. It takes about 17kv to jump a 3/16" gap & 22kv to jump ¼” in the open air. Remember, it’s 14psi outside of the engine & about 90psi at a 6:1 compression ratio in the cylinders & compressed air creates electrical resistance, so you really need the 17-22kv to fire the plugs when the engine is running. A store bought plug checker will work better than an old plug because it won’t shock the snot out of you like an old plug might!
75 Tips
Always, always check your spark first.
When it stalls out get out of the seat and pull a plug wire and VERIFY that you have a bright bluish white spark that jump at least 1/4 inch.
Requires no tools to do this.
Only then go on to fuel.
(quoted from post at 21:05:46 07/06/13) after operating 15 minutes, full throttle on highway in 4th gear, tractor stalls out. It will start with choke wide open but sputters. I have to rapidly open/close the choke just keep it idling. after cooling down seems to run ok. I am not very mechanical but it seems like it is heat and fuel related as opposed to electrical. Any thoughts greatly appreciated.
There's no need to wright a book on you issue...
There's no need to guess either You need yo confirm spark with a rock solid test,,, use a spark tester take the fools guess out of the equation and move on...
Guessing will have you chasing you tail... BTDT got the patch....
