Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 8N Parts Online
Re: 8n stalls out after 15 minutes - carb not getting fuel?
Dell (WA)
07-06-2013 11:16:10
Report to Moderator do know enriched mixture by pumping yer spring loaded choke knob is eazier to sparkle with weak sparkies, don't you???
Our experience sez 15-mins is typical time fer weaksister ignition switch to cause weak sparkies and ruff running and stalling. After cool down of about 30-mins, ignition switch is good-to-go fer nutter 15-mins of eazy runnin'
Keep yer itchy-twitchy fingers off'n them handy-dandy carb tweek'ums. They ain't-chur problem.
BTW, about 1-mins of runtime and stalling out is BAD condenser. NOT yer problem.
About 5-mins of runtime is CLOGGED in-the-tank fuel filter. NOT yer problem.
It takes about 1-hr of running fer yer 1-terminal squarecan ignition coil to cause weak sparkies. NOT yer problem. As said, 15-mins of runtime is BAD weaksister ignition switch. Do I haffta tell you to replace it??? ........Dell, yer self-appointed sparkie-meister
07-06-2013 12:09:33
 Re: 8n stalls out after 15 minutes - carb not getting fuel? in reply to Dell (WA), 07-06-2013 11:16:10
Thanks, i will check it out.
Bruce (VA)
07-06-2013 12:35:01
 Re: 8n stalls out after 15 minutes - carb not getting fuel? in reply to cersbo, 07-06-2013 12:09:33
6v or 12v?
07-06-2013 12:51:37
 Re: 8n stalls out after 15 minutes - carb not getting fuel? in reply to Bruce (VA), 07-06-2013 12:35:01
6V front mount
