Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Lift raises with lever in down position ?
07-05-2013 19:25:46
oil junky or clean?
open inspection panel see if rod from the top is moving valve full in and out of pump body.
post back
07-08-2013 19:52:41
 Re: Lift raises with lever in down position ? in reply to soundguy, 07-05-2013 19:25:46
Soundguy, i straightened the long rod(straight as an arrow now).
ajusted spring according to manual - 3 9/16 inches with small lever(draft control) down, the intake valve dont come all the way out and with draft control up, the intake valve comes all the way out. (is this correct )
I still got a problem as nothing ive done has changed anything.
I have dropped the pump out the bottom and the intake and exhaust are working correctly.
So ant tips where to go from here ?
07-08-2013 21:05:16
 Re: Lift raises with lever in down position ? in reply to dave404, 07-08-2013 19:52:41
I would verify that touch control lever is still keyed to eccentric shaft & that key isn't sheared & slippage occurred between shaft & lever.
